1.) I can see that on tagdive speed booster plugin its written than
“Speed booster for Newspaper 7 and Newsmag 3 themes – It moves the styles and all the scripts of the theme to the bottom when needed. It activates internal theme optimizations for better speed and it adds async js .
Version 4.9.1 | built on 06.03.2019 12:47 | By tagDiv | Visit plugin site”
I have Newspaper 9.6 install, do I still require tagdive speed booster plugin, if not then how the funcationality of this plugin is implemeted in updated versions?
2.) Where can I see the updates made in any new version before installing it.
Hello !
This plugin is not mandatory. I will strongly suggest you to follow this tutorial in order to increase your page speed. Our users have reported very much succes after following it: https://tagdiv.com/how-to-increase-page-loading-speed/
All the updates and changelog can be found at the bottom of this page: https://themeforest.net/item/newspaper/5489609?fbclid=IwAR0CpdITrRLSdGbBOXV5HCWo08J7xIQkktg8JJHh9ZVPNKrN9l8PYYfzOXw
Thanks for reply, there is a plugin called wp data table , they say if I have got bootstrap.js already included in my theme then I can uncheck that option, can you confirm whether newspaper theme already has got bootstrap.js and if yes then what it does , does it help to improve the speed?
Secondly, I used to see Theme Panel without downloading and activating Tag dive composer plugin but not its not the case, Can i delete dag div composed and still be able to use theme panel as tag div composer has got .js file which makes site little slower.
Hello !
Yes, Newspaper Theme has bootstrap.js. Also the tagDiv Composer is a MUST have plugin in order to have full access to Newspaper Theme.
As I’ve mentioned before. For page speed please follow the tutorial I have posted above. Also please make sure that your System Requirements are all up to date: https://tagdiv.com/newspaper-theme-requirements/
