tagdiv speed booster conflict?
i just moved my website to another server, now everytime i open a post it loading all the data but doesnt show anything on screen (blank white), i deactivate all plugin and check one by one to find the culprit, it was tagdiv speed booster, so i deactivate it. Can you please tell me what’s wrong?
i also installed w3 total cache, but i uninstalled it again and activate the tagdiv speed booster, it was the same blank white (but the data was loading, i can see the page source)
are you minifying the css?
Agreed, when I’ve seen a white screen and it’s not a php error, I’ve often found it’s aggressive CSS minifying. Both those plugins should work, but make sure you disable minifying CSS, and then clear the page cache before looking at your site.
What is the minifying css means? And which plugin use that kind of minifying css?
Minifying is reducing file size by removing unnecessary data (e.g. line breaks). Caching / minifying / performance / speed plugins usually do it. The problem is that it can break up the flow of parsing the CSS file (if I understand it right).
Support has said in other threads that minifying CSS through plugins like W3 Total Cache won’t work (and I’ve seen it have the white screen effect). A CDN might also be minifying your CSS files, although I use Cloudflare and it seems fine.
Yes, but I told you that I have uninstalled w3 total cache, but the speed booster still not working
@jazzel
Please make sure you have enabled only the theme required plugins and then check if this issue is still there also consider to update the theme if you are not using the latest version(4.2.2).
Also please remember to send you site’s URL.
Hi, i have updated the version and now all is going back to normal with speed booster active. Thank you 🙂
