Try to deactivate the Speed Booster plugin then check in browser console if the errors still appear. First try to deactivate all plugins except Visual Composer, clear all caches and test again.
If the errors appear only when Speed Booster is activated, that happens because some plugins cause conflicts when their’s resources are moved to footer. You can check a plugin behavior with Speed Booster enabled by adding it on allowed plugins list: http://screencast.com/t/dCMffJFq or by moving its css/js resources at page bottom: http://screencast.com/t/P7r6uHvvJl
For more information regarding Speed Booster please check this topic: https://forum.tagdiv.com/topic/speed-booster-questions/
Hope this help.
