tagDiv Speed Booster
When will this plugin be compatibile with Rev slider 5? Currently I can’t enable it so I am interested when you will update the plugin. If you do not plan on updating maybe I should just downgrade the slider?
Regards,
Ivan
Hello Ivan,
As a quick solution to your problem, you can comment out this section in the speedbooster file http://screencast.com/t/RZLIOPUNdqh to override the plugin compatibility.
We hope in a future update we will be able to implement more plugins in the compatibility function.
Thank you Bogdan!
