I am experiencing a painful situation in developing a site with Newspaper eand I am very concerned about my other 4 site already using your theme.
This site is on schedule for going online when I will be back from holiday and now, after updating, I am not sure what to do with TD VC.
I mean I know that I can’t use it, because the structure I have already created was developed and chosen with the client is not replicable with TD VC as in many part I used 4 colums on one row. I mean it seems insane to me.
But most important i have nearly 30-35 static pages already built: do I have to recreate them all?
And this is just part of the problems: since I updated I can no longer use Text Block with Title in row as it produce a page error.
Also being forced to use front end editor doesn’t allow me to use powerful normal VC integration like Calendarizeit or Eventon. Not mentioning that back-end editor is pure gold in some situations.
I (and plenty of other collegues) need to know for real what you are planning to do.
Can I continue to use normal JS VC?
Will TD VC replace JS VC?
Or fully compatibility will always be guaranteed?
I am really worried as I am leaving for holiday (now forced to take my pc with me) and it was all perfectcly working since updates.
Newspaper was really a state of the art theme (it still is, actually) for simplicity, clear customizations and reliability: please, don’t mess it up!
If you used Visual composer to build your website, deactivate the tagDiv composer.
When you decide to make the switch to the tagDiv composer you can do it at any time you see fit.
The pages will have to be rebuilt with the new editor, and replaced.
Please rest assured, when and if Visual composer will not be included in the package or supported, it will be announced properly ahead of time. I could not say at the moment what will happen exactly.
I have tested the Text block with title and found no issue with it. Maybe you can provide more details about the error it is producing for you, when possible.
In the meantime, please try and enjoy your vacation!
