Tags next to comment counter
how to put the tags next to the comments counter in the title-section?
I tried to move the code, but the tags were below the date. Not so pretty.
You need to edit the template file corresponding with the post template used for post and add this line of code like here: http://screencast.com/t/i00jJmVsWu
<?php echo $td_mod_single->get_the_tags();?>
The result should be like here: http://screencast.com/t/YxUhetAGTo
Please note that I haven’t tested this on other post templates, so I don’t know how it will behave on those cases.
Thanks, works great!!! 😀
Hi Andrei,
now I want to put a <h3> </h3> around the Tags. But if I do this, the tags are moving down. How can I achieve this?
Before:
With the <h3> it looks like this:
Push.
Sorry for delay we somehow missed your post.
Assuming that you insert the h3 tags like here: http://screencast.com/t/VjWl3QZ1S1X you can try this custom css ion theme panel > custom css: http://screencast.com/t/D6qRnNHIJU
.td-tags h3 {
margin-top: 0px;
margin-bottom: 0px;
.td-tags {
display: inline-block;
Thanks! 🙂
But i need to wrap the whole construct including the term “Tags” (or in my case “Deine Stars:”) in <h3>. And not every tag for itself.
I tried this:
<h3><?php echo $td_mod_single->get_the_tags();?></h3>
But than it looked like this:
Push ^^
Try this custom css: http://screencast.com/t/1a24IGX0v
.td-post-header h3{
margin-top: 0px;
margin-bottom: -5px;
margin-left: 5px;
Thanks, it works! 🙂
