TD composer does not work on my home page www.serrespost.gr
I cannot add elements in the home page using TD composer.When I drag an element only the name of the element appears.
Not the element placeholder with the element options. The tagdiv composer works fine in other pages.
I have attached a relevant screenshots and my system status.
Screenshots:
https://adobe.ly/2Bv8OGi
System status:
Registration key i 0a59519b – **** – **** – **** – 31b6b925c86e Reset key
Theme name i Newspaper
Theme version i 8.7.2
Theme database version i 8.7.2
HTTP channel test wordpress
Installed demo i Default Demo – demo ID: default | install type: full
Theme Mobile Newspaper mobile version
php.ini configuration
Server software i Apache
PHP Version i 5.4.45
post_max_size i 8M – You cannot upload images, themes and plugins that have a size bigger than this value. To see how you can change this please check our guide here.
max_execution_time 70
max_input_vars 2000
SUHOSIN installed false
mbstring available
WordPress and plugins
WP Home URL i http://www.serrespost.gr
WP Site URL i http://www.serrespost.gr
WP version i 4.9.4
WP multisite enabled i No
WP Language i el
WP Memory Limit 64 MB/request
WP_DEBUG False
Caching plugin No caching plugin detected – for best performance we recommend using WP Super Cache
If the issue is happening only in the homepage then that would suggest that something in it is causing it. Try making a copy of the page code
– https://www.screencast.com/t/hg3VHeWXN
Enter all the code in a new page and see if there is still a problem. If there is, begin by gradually removing elements from it while saving and refreshing the page and checking if the issue is solved. Maybe you can identify what exactly is causing the issue. let us know the results.
