Td composer does´t not work with demo TRAVEL
I have installed NewsMag with 1 click install, Demo “Travel”
I try “Edit with TD Composer” but I can not see the preview of page for configurating the site… The side right is white
What is the problem?
I hav after the last Update the sam Problem?
Hello all,
Sorry but the TD Composer should work as expected for all of our demos. I have tested on my website and it seems to returns best results, as you can see here -> https://www.screencast.com/t/5OKVMzPiyJ1U
If the problem is still there, make sure that you have right installed the latest version of the theme via FTP way because this is the surest method in this case.
