TD Composer JS problems
When I active TD Composer or the theme I have problem in the back with JS. Lot of things stop working (fast editing from the post list, change the URL, …) And I get lot of errors in the console with different scripts. All the errors disapear if I deactivated TD Composer.
Uncaught TypeError: o.widget is not a function
at wp-pointer.min.js?ver=680966206710d21a0613c8ee258f82fd:2:31
at wp-pointer.min.js?ver=680966206710d21a0613c8ee258f82fd:2:3578
menu.min.js?ver=1.13.3:9 Uncaught TypeError: a.widget is not a function
at menu.min.js?ver=1.13.3:9:223
at menu.min.js?ver=1.13.3:9:178
at menu.min.js?ver=1.13.3:9:188
sortable.min.js?ver=1.13.3:9 Uncaught TypeError: Cannot read properties of undefined (reading ‘mouse’)
TypeError: f.find(…).hoverIntent is not a function
Have you checked for a plugin conflict? Please deactivate ALL plugins except tagDiv ones; also, if you use a child theme or cache plugin, deactivate them, clear all cache, and try again.
Also, please let me know the PHP, WordPress and the theme versions.
Hi Anamaria, it was a problem with Wordfence plugin. Thanks for your help.
Normally it should work with the wordfence; maybe there was an option that interfered.
