Hello – I am trying to EXCLUDE a post from showing on my homepage, by adding the post ID to the field “Exclude Post ID” inside the “Post Loop” Column type.
Doing this INCLUDES only the post ID added, the exact opposite effect. Am I doing this wrong? Is this feature working as intended?
In order to exclude a post you’ll need to set it with this prefix “-” -> http://prntscr.com/pzy2wa -> https://forum.tagdiv.com/flex-block-settings-guide/
I am using the “Post Loop” Element type on my home page. It does not have a Filter tab like the blocks, just an “exclude post ID” which has the opposite affect of it’s name. It only INCLUDES whatever post ID you add.
Is there no way to filter posts using Post Loop?
Using the post loop element the procedeure is the same, but you’ll need to set the ids in this field -> http://prntscr.com/q0ieq6 -> http://prntscr.com/q0ifr7, unfortunately there is no filter on post loop, sorry, dis can be only order or set fix posts -> http://prntscr.com/q0igoz
