Td Composer problem and white screen of death
since this morning i have problem with Newspaper theme and namely composer plugin.
In one moment, after not installing anything or updating, i was just searching site database in Participants Database plugin, i received white screen of death but only on admin dashboard (it works normal for visitors).
I have renamed plugins folder, which resulted in restored access to admin dashboard. So i have changed name of plugins folder to plugins.old, formed new one and started checking plugin by plugin. On very start, as soon as i reinstalled Composer, alone in plugins folder, white screen of death comes back. This didn’t happen to any other plugin.
Then i noticed that in Newspaper part of dashboard if i start installing of plugins, i m getting Ajax error.
I ve turned on debug and these messages i m getting first for Newspaper dashboard and second for white screen of death after i put Composer manually and activate it.
Fast Start Your Website
Warning: ftp_fget(): Failed to open file. in /var/www/html/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php on line 146 Warning: ftp_fget(): Failed to open file. in /var/www/html/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php on line 146
1. Install or Update the required Newspaper plugins
https://ibb.co/1mPNM4v
https://ibb.co/M6z8RT7
Install premium plugins
Install the included plugins with ease. All the plugins are well-tested to work with the theme and we keep them up to date. The theme comes packed with the following premium plugins:
Fatal error: Uncaught TypeError: ftp_fget(): Argument #1 ($ftp) must be of type FTP\Connection, null given in /var/www/html/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php:146 Stack trace: #0 /var/www/html/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php(146): ftp_fget(NULL, Resource id #264, ‘/var/www/html/p…’, 2) #1 /var/www/html/public_html/wp-content/themes/Newspaper/includes/wp-booster/wp-admin/tagdiv-view-theme-plugins.php(125): WP_Filesystem_FTPext->get_contents(‘/var/www/html/p…’) #2 /var/www/html/public_html/wp-content/themes/Newspaper/includes/wp-booster/tagdiv-wp-booster-functions.php(499): require_once(‘/var/www/html/p…’) #3 /var/www/html/public_html/wp-includes/class-wp-hook.php(324): {closure}(”) #4 /var/www/html/public_html/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(”, Array) #5 /var/www/html/public_html/wp-includes/plugin.php(517): WP_Hook->do_action(Array) #6 /var/www/html/public_html/wp-admin/admin.php(259): do_action(‘newspaper_page_…’) #7 {main} thrown in /var/www/html/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php on line 146
There has been a critical error on this website. Please check your site admin email inbox for instructions.
https://ibb.co/c6RbF8T
And this one for white screen of death:
Fatal error: Uncaught TypeError: ftp_fget(): Argument #1 ($ftp) must be of type FTP\Connection, null given in /var/www/html/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php:146 Stack trace: #0 /var/www/html/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php(146): ftp_fget(NULL, Resource id #64, ‘/var/www/html/p…’, 2) #1 /var/www/html/public_html/wp-content/themes/Newspaper/includes/wp-booster/wp-admin/plugins/class-tagdiv-theme-plugins-setup.php(356): WP_Filesystem_FTPext->get_contents(‘/var/www/html/p…’) #2 /var/www/html/public_html/wp-content/themes/Newspaper/includes/wp-booster/wp-admin/plugins/class-tgm-plugin-activation.php(1977): tagdiv_theme_plugins_setup->theme_plugin_has_update(‘td-composer’) #3 /var/www/html/public_html/wp-content/themes/Newspaper/includes/wp-booster/wp-admin/plugins/class-tgm-plugin-activation.php(1836): TGM_Plugin_Activation->does_plugin_have_update(‘td-composer’) #4 /var/www/html/public_html/wp-content/themes/Newspaper/includes/wp-booster/wp-admin/plugins/class-tgm-plugin-activation.php(422): TGM_Plugin_Activation->is_tgmpa_complete() #5 /var/www/html/public_html/wp-includes/class-wp-hook.php(324): TGM_Plugin_Activation->init(”) #6 /var/www/html/public_html/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(NULL, Array) #7 /var/www/html/public_html/wp-includes/plugin.php(517): WP_Hook->do_action(Array) #8 /var/www/html/public_html/wp-settings.php(700): do_action(‘init’) #9 /var/www/html/public_html/wp-config.php(121): require_once(‘/var/www/html/p…’) #10 /var/www/html/public_html/wp-load.php(50): require_once(‘/var/www/html/p…’) #11 /var/www/html/public_html/wp-admin/admin.php(34): require_once(‘/var/www/html/p…’) #12 /var/www/html/public_html/wp-admin/plugins.php(10): require_once(‘/var/www/html/p…’) #13 {main} thrown in /var/www/html/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php on line 146
https://ibb.co/b1zMCKx
Do you have ideas whats going on and help me, please?
  • This topic was modified 2 years by brue.
Since i have few licenses and few websites with same combo – Newspaper theme and Composer, i ve tried to move folders of theme and plugins from server to server, from those that works to this one that has problems, but it shows same errors. Same with newly downloaded complete version of Newspaper files from themeforest.
Might be PHP version too high? 8.4 still problematic. 8.3x works.
Tnx, but on problematic site version is 8.1.14
On other two, which i mentioned that work ok with same theme+plugins, versions are 8.0.30 and 8.2.22
This is very strange because all the errors don’t come from the theme files. Can you please reinstall the WordPress and the theme and disable the extra plugins?
Thank you on reply. I ll try do everything from start and see how it goes. Might be some server settings at hosting provider makes problems. New install will show it I hope.
Please let me know the results.
Have a great day!
