td composer problem
I’m having problems to use tdcomposer after the update. The text element is not working properly, I put the text and it’s not saving. I tried to deactivate and upload the plugin again, but still not working.
Error on console firefox:
tagdiv_theme.min.js?ver=8.7:160 Uncaught TypeError: Cannot read property ‘top’ of undefined
at Object.compute_top (tagdiv_theme.min.js?ver=8.7:160)
at eval (tagdiv_theme.min.js?ver=8.7:312)
compute_top @ tagdiv_theme.min.js?ver=8.7:160
(anonymous) @ tagdiv_theme.min.js?ver=8.7:312
These would be the first steps to take in this case. Check the theme system status section
Ask your hosting provider to increase the allocated resources if needed. Deactivate all plugins except theme plugins, then check if the issue is solved. There seems to be an error, this could be caused by a plugin interfering with the theme. Let us know the results.
