Hello Guys! I Have a problem with right click in TD composer…when I click nothing happen…
Can you help me?
I tested it and it seems to work – https://i.imgur.com/1puch6K.jpg
Are you using the latest Newsmag theme version (4.9.6)?
If you do, and the right click menu is not working for you then there is a problem in your case. I suggest sending us an email at contact@tagdiv.com with a link to the website, admin login, and a link to this forum topic. That would be the fastest way for us to try and find out why it does not work on your website. Let us know.
