The td-js-loaded class is defined when the page loaded. So it cause the mobile menu not show when current page is not load completely.
Sometimes, google ads script or some plugin have problems, they will keep loading for long long time and it will break the site.
Do you have any solutions for this?
Thank you
Hello Leekad,
For more investigations in this regard, you should edit the style.css theme and remove the specific class, like this -> https://www.screencast.com/t/S4Vyw7V6mYt
Hope this helps!
