i use 8.7 theme version with js composer for making page
if i load via ftp new version of td-social-counter plugin, I get the code below instead of the button
[td_block_social_counter custom_title="" style="style7 td-social-boxed" facebook="name" facebook_app_id="0000000000" facebook_security_key="00000000000" facebook_access_token="0000000" twitter="name" googleplus="+name" open_in_new_window="y"][td_block_ad_box spot_id="custom_ad_1"]
moreover in js composer backend editor, the code is strangely displayed as text.
the social block has disappeared…
Going back to the old version 4.2 of the plugin (contained in theme 8.6) everything works well.
How to solve?
That issue was solved in theme version 8.7.1, there was indeed a problem in 8.7 when the social counter will not appear in Visual composer unless the tagDiv composer was active. However now it is fixed, update the theme and there should be no problem.
