TD speed boost messing with Digg-Digg plugin
Hey guys..
I love using the Digg Digg social plugin but when ever i have TD speed boost enabled the floating lefthand twitter bar does not work..
any ideas?
Unfortunately the SpeedBooster plugin may not work with all plugins as it’s using a minified version of the theme js. Caching / minifying / performance / speed plugins usually do this which can break up the normal flow of some plugins or could generate js errors so if you want to use that plugin disable the SpeedBooster plugin.
Sorry about this!
