td-speed-booster BUG in RTL
HI
In normal without td-speed-booster :
http://prntscr.com/3luyhd
But when active the td-speed-booster plugin the main menu reversed like in image :
http://prntscr.com/3luzgj
not only in main menu but also on blocks styles so any help for that ?
Can you provide a link to see the issue? The plugin is still in beta and we permanently improve it for compatibility with all functionality and common used plugins.
Sorry i can’t active td-speed-booster plugin in my site because it’s makes this problem < you can try it on Arabic WordPress version or any other RTL WordPress version >
Ok, i will add this on our todo list for an investigation, please don’t use it until we have a working solution.
Thank You Marius
