Hey Guys,
I am not sure if this is a theme issue or my own issue but thought I’d run this by you.
I had about 800+ users on the site at once and it was running slow and intermittently giving errors about not being able to connect to database , so I called hosting who had a look and advised there’s an issue with td_module_9 in the child theme having so many php connections to the database that haven’t been closed for more than 2 minutes, and they said these connections should usually close within a few seconds.
The strange part is that I believe I am not using module 9 at all !
Again , I do have some mods in my theme , so this could be my own issue and sorry to waste your time .. if the solution would be to delete this module from the child and main theme then I could do it.
I will flick you a separate emails with the site details.
Cheers,
