td_speed_booster not working in Posts
The plugin (td_speed_booster) works perfectly on the homepage and category pages.
But it does not work in posts.
The plugin is not doing the work of moving the CSS files to the footer in all posts.
Can someone help me correct the problem?
Thanks in advance.
Hello dsigners,
Please keep in mind that not every time the Google (page speed tool) returns the good results. Please try to check your page source (CTRL+U) and check if your resources were moved to the footer section. Also, if you are using some tested plugins, please try to disable all of them and use only the plugins that come bundled with the theme packet and rule out any conflicting plugins. Notice that until now, we does not have any bad reports in this regard.
