Templates for single post – Fonts
Hello –
I’m working on a single post template – under the single post content – under the style and fonts – I’ve changed the main font and then there is all the H1’s and pull quotes and other fonts – is there a way to quickly make all those other fonts – mimic the font as picked above?
For templates – do these draw from a main theme setting somewhere?
If you use a cloud/PRO template, you need to edit that template and change the font for any elements. For example, if you edit a post template and all your posts use that template, then it should change automatically on all your posts.
For default templates you have some settings in theme panel.
Thanks –
So for every individual element – and such – the fonts have to be changed individually – -there is no way to say – – apply this font to all the elements in this template?
Hello !
For anything external than elements you can use the feature from Website Manager as you can see here: https://www.screencast.com/t/91oeCWC1jtX9
I hope this was helpful !
