Templates for Tags, Category are looping and showing the same set of posts
Hi, Didn’t realize until some time after making use of your cloud templates for Tags and Categories.
Every numbered page shows the same exact posts from the first one. Like a loop.
Had to go in and reset to No-Template.
Please make sure that you are using the last version of Newspaper theme, v10.2
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
Let me know the results!
Thanks for the quick reply Calin.
Yeah it was 10.2 but then I noticed my max_execution_time and max_input_vars were below where they were before…due to my recently switching to PHP 7.3 from 7.2
Might that have been it?
Anyhow, Works now. Thx.
Yes, sometimes the theme requirements make the difference.
I’m glad that the problem was solved.
