text box problems with WP 4.3.1
Hi, I have problems with the text box from last WP update (4.3.1). In fact I can’t edit any text and I only can see the HTML but not the visual style.
Please, Can you help me?
  • This topic was modified 10 years by vac.
Try clearing your cache, try using different browser.
Hello vac,
You can try to clear your cache as Chris said and disable all plugins except visual composer and see if the problem is still there. If it is, please provide more details so we can closer inspect the issue.
first of all, thanks
I cleared my cache but I have the same problem. I can’t edit or add any text because the text box doesn’t work as before mainly because I can’t see the text in the editor box, I can’t see the text options that usually appears on top.
Regarding the browser, I ussually use chrome but I tried with explorer and no changes, I have the same problem
Please make sure you have shortcodes selected in visual composer settings:
http://screencast.com/t/zPfQ2MtmT6
Thank you
yes I did it but the problem continue.
thank you
What theme version and visual composer do you use? When this issue appeared?
Please provide more details and send an email at contact@tagdiv.com and provide wp-admin access so we can take a look, also paste a link to this topic so we can know who you are and what your issue is.
The problem only exists within the visual composer itself. The formatting of the module is non-existent, the text is almost like data text with visible formatting tags but i can only see that if i highlight the text as it’s white on white background and i can’t even edit it anyway. I couldn’t’ edit text and i couldn’t add anything further.
I have connected to the platform using another computer and it works perfectly. I don’t know what is the difference, it could be java problems?
Please make sure you update the Visual Composer plugin to the latest version provided with the theme. What theme version do you use. It should not be any issue if you use the latest version. I’m not sure why you have this issue, only on your computer, please clear cache and also the browser cache. If the issue persist check the error.log file and also you console for errors.
