Text in footer confined into a narrow column that does not autosize on mobile
I added a footer using tagdiv-composer which works really well on desktop. I am using an inner row which has a four column layout, and setting the first column to a width of 50%, while leaving the width setting for the other three columns blank. Here’s a screenshot: https://i.imgur.com/u5yig53.png
The problem is that on mobile the first column does not autosize and is confined to a narrow band (see it here https://i.imgur.com/XbTxQ1i.png). I have spent two days playing with the various settings to fix this without success. Please help!
You can set the 100% width on mobile for your column: https://prnt.sc/aoCRrWzyb13H
Oh my gosh so simple thank you so much!
