the background of my mobile menu display in low quality
My mobile menu is working well but the background image of the menu that I set using the theme panel is displayed in low quality. I set the background image to 692×1094, it gets a little better but it’s still quite pixelized.
Is it possible to display a HD image ?
My website : https://racelab.io/
Add your background-image in that section from here -> https://www.screencast.com/t/rp9ggjYEkhwj, clear all the caches, purge CDN files and check the results. Provide some useful screenshots with the results after you have made these changes.
I tried to do as you showed me on the screenshot. But now I don’t have an image anymore on the mobile menu.
https://image.noelshack.com/fichiers/2019/18/2/1556626174-racelabproblem.png
I’m using the mobile theme, maybe it’s the reason?
If you are using the mobile theme, that setting can be changed from here ->
https://www.screencast.com/t/HzNBLlZagw
Hope this helps!
The background is displaying now, but still in low quality. I will add screenshot:
http://image.noelshack.com/fichiers/2019/18/4/1556811259-59660180-298268671095334-2434663784388755456-n.jpg
It is in low quality because a small thumbnail is used. When setting the image, please select a larger size or the full size, for a quality result – http://prntscr.com/njx8h1
– http://prntscr.com/njx8ne
If a thumbnail is used it will be stretched, the result will not be so good.
Problem solved! Thanks a lot!
