Checked my posts and realized that most of the font color of my website is in light grey. I never changed the color. It should be black, the only black colored font is in bold. I have changed all the post content font color to black under Newspaper-Theme panel but nothing is working. WordPress is also not able to figure out a solution. How do I fix this?
I think that you are using a PRO demo or cloud templates, that is why the theme panel settings are not apply. Using cloud template from tagDiv Cloud Library, you’ll need to edit the cloud template using tagDiv Composer and set on the elements the color and style you want
Hope this will help you!
Let me know the results!
