The problem with password protected article
Hello, I have a problem , I want to password protect a part of the items wordpress but after entering the correct password does not show the content , which may be the cause ?
The theme doesn’t come with such functionality, i presume you’re using a plugin so my advice is to ask on the plugin support forum about it’s functionality.
Thank you, Emil G.
ok. thanks
