Hello.
I use two popups on my site. One for wide screens and one for mobile view. However, I have a problem, even if the popup is closed, the links and logo in it can be clicked. Like this: https://prnt.sc/-lNkuqZeIp05
Helped with this from the TagDiv team, but it didn’t completely fix the issue.
Added this code to CSS for solution;
@media (min-width: 767px) {
#tdm-popup-modal-td_m_5d6f.tdm-popup-modal-over-screen .tdm-popup-modal {
transform: translateY(calc(-100% - 1px))!important;
However, the problem still persists as below.
Do you have a permanent solution suggestion?
*Site link: https://mcthukuk.com/
Can you please try this custom css for mobile:
display: none;
#tdm-popup-modal-td_m_5d6f.tdm-popup-modal-over-screen.tdm-popup-modal-open .tdm-popup-modal {
display: block;
The code was set in the the theme panel > custom code> advance css> in mobile section.
Please check the website and let us know the results!
I hope this will help you!
