The same Facebook comment appears on every post
I managed to follow the instructions given here >> https://forum.tagdiv.com/topic/facebook-comments-2/ on how to have the FB comments plugin and I got it to work. However, I just noticed that the same comment will appear on every single post.
Here’s my website so you can check it out. http://dognmeows.com/
I’d appreciate it if you look into it and solve my problem. Thank you so much.
It seems to work for the other users. Try clearing any caching installed, maybe that is why the data is not refreshing. Or go through the mentioned steps again, to make sure you have made the modifications exactly as described in that topic.
Hi, Simion..I’m sorry but i already modified all the things as instructed in the previous post. Cleared cache and still the same.. The plugin works but the same comment will appear on every post? Is there a tweak that you can help me with?
It could be related to the code you entered in the post loop file. Check if it is exactly like shown – https://www.screencast.com/t/eHQZvldyMz
Or maybe you can try other examples for this code, like in this topic describing a similar problem
– https://stackoverflow.com/questions/8862411/facebook-comments-plugin-same-comments-on-every-page
