Theme activation problem
Hello, I bought my newspaper theme for my website called habersembolu.com. However, I change my theme, and now I want to use the theme on my site called habermektebi.com. I installed the theme, but it does not work and a text appears as I sent. What should I do here? Can I use the theme on my website Habermektebi.com? I want to use the theme on my site called habermektebi.com. How can I activate it here?
I can forward you login information if needed.
To use a license key in a different domain, you can unassign it from the list at any time after 2022-12-07 11:44:44 UTC + 02:00.
If you encounter problems, please contact us at:
https://habermektebi.com/
  • This topic was modified 3 years by newlife.
Hello @newlife!
You can use a license key for one single product, but if you want to move the theme to another website or change domain/migrate, you’ll need to reset the license key from that website: https://www.screencast.com/t/Zt12bpyX and remove the theme (delete), in this way the license will be available for the new website and you can use the theme without any problems.
Hello, I did as you described, I reset the license key, I re-entered the old license key, but it didn’t work. What should I do? I deleted the theme from my previous site and installed the theme on my new site, but it didn’t work. In the status, both domains are active, but on the side, it is written in red because it is not active for my two domains. What should I do? What should I write in its place after resetting the key. I did what you said before but it didn’t work.
  • This reply was modified 3 years by newlife.
Hello @newlife!
You can use a license key for one single product. We’ve introduced the Manage License System, which can be seen in the 11.4.3 version of the theme in Newspaper -> My license. You can assign or unassign a domain from there. One can be used for staging and one for your live website. That message appears if you try to unassign a domain so often, so you need to wait until that date.
According to Envato license terms, a theme can be used for a single end product (website):
https://themeforest.net/licenses/standard
https://themeforest.net/licenses/terms/regular
Hello, I am trying to use the theme on a single site already. However, it doesn’t work, I get a message like the one I sent. Shall I send you login information via e-mail?
Hello @newlife!
This message appears if you try to unassign a domain so often, so you need to wait until that date.
Thank you for understanding!
I need to use the theme before this date. Can’t it be fixed in another way?
Hello @newlife!
Unfortunately, no. This message is very clear there.
Merhabalar, habermektebi.com adlı web sitemde temamı aktif hale getirmek istiyorum. Temam daha önce farklı bir sitedeydi ama oradan kaldırdım. habermektebi.com adlı sitemi aktif hale getirmek istiyorum, ne yapmalıyım?
Please contact us via email and please provide the license key, and wp-admin access please include the link to this website in the email so we can identify you.
We’ll check the problem as soon as possible.
Hello, I have sent you the relevant information by e-mail.
Please let me know the subject of the email.
Merhaba e postayı yeniden gönderdim. Konuyu da ekledim. Oradan kontrol edip dönüş yapar mısınız ?
