Theme Color Settings Cache Problem
Dear Sir
I changed the color of the theme from the default blue color, to orange color.
PROBLEM:-
1) Whenever i open the website, it loads the Blue Color first, then changes to the orange color.
2) The problem is caused due to the tagdiv Speedbooster plugin. When disabled, this problem dissapears completely.
3) Maybe we need to clear the cache generated by the plugin, please suggest a way to do so.
Read this topic on the forum, other people are facing the same problem.
https://forum.tagdiv.com/topic/header-color-loaded-in-blue-background-before-loading-red-background/#post-166538
Best regards
Vishesh
The speedbooster plugin will move the css to the footer of the site. That means it will load last and you will be able to see the original css before the theme panel css loads. In order to prevent this you can either remove the style.css from the speedbooster code: https://www.screencast.com/t/ygx12ohW0V or change the colors directly in style.css
Can you please suggest how to change the default colors directly in style.css, since removing the lines from tagdiv speed booster plugin did not work.
If you disable speedbooster and the problem goes away it means you are not removing the correct stylesheet from the plugin or you did not clear the cache after you removed the code. If you want to alter the style.css you will have to create the color change css code and add it at the bottom of style.css but you will need a bit of css skills for it.
