Hi There,
I’ve recently purchased Newspaper theme and configured the “Black Pro” demo (https://demo.tagdiv.com/newspaper_black_pro/). The issue is that Theme fonts (https://prnt.sc/1sb7sdc) setup inside THEME PANEL is not showing on the website.
Can you please help me on this?
You have a pro, so the changes from the Theme Panel for fonts and colors will not apply, to change the font on block/post you can edit with tagDiv Composer -> https://prnt.sc/10grx77, select the block/post and in Style, you can change the font => https://www.screencast.com/t/sUE7ug4UIAR5 and color => https://i.imgur.com/Lc559Rz.png
This is a video about how to change the fonts => https://www.youtube.com/watch?v=rbkYVyj1__Q
Hope this helps you!
Hello Anamaria,
Thank you for sharing the information. What you described that all I know it. The interface provided in the theme to changing fonts and colors block wise will take lots of time. I am not sure what is the logic behind to provide facility for each block/post instead of Global option.
Unfortunately, there is no global setting to set color on the website, for all blocks, but if you want you can copy the style for the title, image, category tag, meta info and excerpt => https://www.screencast.com/t/APIkNp7q, but be careful, it will copy everything (color, font), for other elements from the block, you need to do the changes on each block.
