Theme fonts changes not reflecting
Hello, I am changing the font size from Theme fonts settings, but the changes are not reflecting in the website.
Kindly suggest
If you install a Pro Prebuilt Website the changes from the Theme Panel for fonts will not apply, to change the font on block/post you can edit with tagDiv Composer -> https://prnt.sc/10grx77, select the block/post and in Style, you can change the font => https://www.screencast.com/t/sUE7ug4UIAR5
This is a video about how to change the fonts => https://www.youtube.com/watch?v=rbkYVyj1__Q
Hope this helps you!
