Hello
I have a problem with fonts.
I was checking some font styles and I notice that some of them don´t change. I restored all of them by default but anything happens. I have checked the website in many browsers and different kind of fonts are displayed, depending on my previous changes.
I have clean caches with WP Super Cache but anything happens.
How could I solve this?
Hello Albert,
Please try to disable all the active plugins, except Visual Composer, clear all caches, purge your CDN file if you used and install only the plugins that come bundled with our theme and try again.
After this changes, if your problem is still there, please provide your URL website so we can further inspect the issue.
Thank you for the message!
Hello
It seems that I have solved the problem after disabling some plugins. So, in this case, if I try active them again, will I get the same error? I need most of them. If it is a problem of WP super cache, could I change to W3 Total cache?
I have another general doubt about fonts. As you say in documentation, using many fonts could slow down the website. For example, could I change all default font family with just two styles and get good results?
Also, is it possible to change the size of articles titles on homepage? I can´t find the option.
Albert.
Hello Albert,
Unfortunately, it is possible when you enable all your plugins, errors occur again. In fact, there is a conflicting plugin. We recommend using only the tested plugins, as you can see in this screenshot http://screencast.com/t/3XkYOUwpe . WP super caches is a tested plugin, but this will may create a conflict with another untested plugins as you are used. The only option for you would be to search for other plugins to do the same thing but not to cause errors in the theme.
When you are using many types of size in theme, the speed of website will slow down because the theme has to be loaded more details and is required more time. You may use the all the fonts as default with just two styles as you said above…the problem with “slow down” appears when you use more than 2,3,4,…10 style.
Our theme are using h3 tag to display article titles. If you want to change the size of this, you have to use a bit of Css, like this:
.home h3 {
font-size: 20px!important;
The result you should see here:http://screencast.com/t/k7Mr296li
Thank you for your understanding and sorry for the inconvenience!
Hello
I haven´t solved the problem yet, I have noticed that font is different in some browsers and mobile. I have a conclusion about what´s happening. I think is not a plugin problem.
First of all, I changed some styles to Open Sans Condensed and Open Sans from Theme Panel. I noticed that these styles aren´t installed in my computers, mac and windows… which is strange because it´s a common font.
Then, I downloaded and installed these font in my computers and they were displayed on the website. If I remove them, the font showed is by default.
So, in this case, how could I display these styles to people´s computer? I suppose that there must be a way to show them.
If the problem is gone without plugin then it’s a plugin issue. Disable all of them again and check your fonts. They should be loaded from the server not the PC/laptop or other device. If the problem is still there without plugins and you still cannot change fonts and have them load properly, please send an email at contact@tagdiv.com and provide wp-admin so we can take a look. Also include a link to this topic.
