Theme fonts section don't work
Trying to change the fonts size of header, I discovered that the all options of the “theme fonts” section don’t work. The error from console is:
500 Internal Server Error
638ms
load-sc…ver=4.1 (riga 4)
“NetworkError: 500 Internal Server Error – http://mydomain.com/wp-admin/admin-ajax.php”
I discovered just now that all theme options give me the same error when save!
Excuse me! My site url: http://ildragoparlante.com
I carefully followed the guide, and I verified that Newsmag goes in conflict with 2 plugins:
* Jetpack 3.3
* WordPress SEO by Yoast 1.7.1
When I activate one of them the theme crash with “NetworkError: 500 Internal Server Error – http://ildragoparlante.com/wp-admin/admin-ajax.php”.
To activate these plugins succesfully without error, I need to deactivate not only Newsmag theme, but visual composer too.
Sorry for the delay!
Please also make sure you empty cache as well and make sure the theme actually saves settings. The issue with saving settings usually appears because the server security module blocks the access to admin-ajax.php file which I noticed you also get . Try to verify if this happens when you save settings in other cases in theme panel and also verify the console for error while saving the settings on the Theme Panel, usually it displays a 403 or 404 error.
Contact your server administrator and explain the situation, as it’s requested many times during the a save the file it’s treated as threat so it’s banned.
Hope this helps! Please let me know how it goes!
I don’t know how to clear cache of wordpress or theme, please say me.
Yesterday I explained to hosting my problem and in the server log there’s a php memory errors (this is from this morning):
[Tue Feb 03 10:32:27 2015] [warn] [client xx.xxx.xxx.xxx] mod_fcgid: stderr: PHP Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 7680 bytes) in /xxx/xxxxxxx/xxxxxx/ildragoparlante.com/public_html/wp-includes/class-feed.php on line 39, referer: http://ildragoparlante.com/wp-admin/
I send it now you warm about admin-ajax.php.
I don’t have any problems or errors on saving options in the theme panel when jetpack and seo plugins are disabled.
load-sc...ver=4.1 (riga 4)
POST http://ildragoparlante.com/wp-admin/admin-ajax.php
200 OK
1.11s
200 OK
586ms
IntestazioniPostRispostaJSONCookie
{"wp-auth-check":true,"server_time":1422958238}
200 OK
819ms
200 OK
729ms
200 OK
558ms
  • This reply was modified 11 years by SilvioTO.
To check for errors in the console follow this – http://screencast.com/t/0eZ8bdF8j
Error 500 is a generic server error – http://pcsupport.about.com/od/findbyerrormessage/a/500servererror.htm
We need more specific information, if you have access to the error.log (you can find it via ftp or c-panel) file please send us a copy via email at contact@tagdiv.com
Thank you, Emil G.
