Theme Header and Footer Style Options Not Showing.
Hope you all are well. Some days ago I bought a Newspaper theme and I install and verified it.
In my theme panel Header and Footer style Options not showing at the backend as well as the Front end. Here is my website: https://fryingfeature.com/
Please check it and guide me on how can I resolve this issue.
i am facing same issue, i had tried to download new header and footer layout
it was able to edit that layout only that time,
now downloaded layout is same not able to edit.
‘edit in div editor not coming’
@usmanramzan
Please make sure that the tagDiv Standard Pack plugin is active on your site because I saw you have a standard template. If it isn’t, please install and activate it.
@theflashupdate
The footer templates do not have the button to be edited with tagDiv Composer in the backend, the footer can be edited only from the frontend if it is assigned, edit a page/post template with tagDiv Composer and go down to the footer. => https://www.screencast.com/t/rpfNhfyrF that page can be private, but the header template has the button to edit with tagDiv Composer => https://www.screencast.com/t/aFaeEdEpT
