Theme Newsmag does not save settings
Greetings, bought a theme Newsmag, installed on site, installing plugins, activate the theme, but the theme is not working properly .
1. There is no save button
2. Background of the control panel theme gray rather than blue
3. In the ” category” errors appear
How to fix the problem?
Screenshots:
http://rghost.ru/private/6mSFKVfCS/8ee6e18bdb65718803d87225aa4d6c91/image.png
http://rghost.ru/private/78MmDbv5L/411c82d75948a0dae9d746eea2b45bc3/image.png
http://rghost.ru/private/88WJFk5Nd/3016891f0501b43dfe3fd2a9a9e80606/image.png
Make sure you cleared all your cache, CDN cache, cloudflare, etc.
Make sure you fully clear your browser cache.
Try turning off all plugins except Visual Composer to see if conflict with an oddball plugin.
Make sure you previously increased the default memory for your site from 40MB to at least 96MB in the wp-config.php file (mandatory!) – -128MB if your account supports it; 256MB if allowed.
It does work 🙂
Thanks Chris!
@Geronimo11
What theme version do you use as we’ve had that issue in a previous theme version however that was fixed in the latest theme version so please make sure that you have the code structured in this td_panel_categories.php file: http://screencast.com/t/rLIWJrf35W like this: http://pastebin.com/Lp6MWGgW If ti doesn’t look like the one I’ve provided please make sure that you backup tat file then replace it’s content with the code I’ve sent you then save it and test again.
Let us know how it goes and provide your admin login details so we can have a closer look at this and send them via email at contact@tagdiv.com
Please also include a link to this tread into your message!
