I dont want my theme to be responsive, so i removed all media files. The problem is that when i open it with any device it doesnt fit to the screen but is half cut. How can i make it to automatically fit to screen width
http://www.gazetapanorama.net/
The theme was designed to be responsive and for that the media queries are used, so if you remove those the site will behave like it does in your case. The theme doesn’t have any option to remove it’s responsiveness and that it’s not an easy task because it needs tests. If you needed you can look for a freelancer on site’s like studio.envato.com
