Dear Support,
I really like this theme you’ve made. The only issue I have is when I go to Theme Panel > Categories and select one category and try to make some changes and press save settings, the tick shows up after a few seconds but nothing is actually saved when I check. Do you know what I’m doing wrong? Thanks
What you can do is to disable all plugins or one by one and see if works, could be a conflict with one of them.
If still not working, can you provide us access to your WP to take a look? Send via email at contact@tagdiv.com
hi,
the server your host on has probably post_max_size in php.ini set to a low number, or the admin has installed the suhosin security feature on it, who also limit the post variable number.
there is nothing you can do about this, only to move to another server.
you can test for this if you install the theme on your computer, if it saves then the describe above is the problem.
Thanks for you message.
Radu A.
Hi Radu,
I followed the instructions given by the first comment:
http://www.wpbeginner.com/wp-tutorials/how-to-fix-the-custom-menu-items-limit-in-wordpress/
I will send you a few screengrabs via to support email address. thanks
