Theme Panel Fonts changes Posts, but not Pages
Hi, when I go to:
Theme Panel – Theme Fonts and change the fonts in Posts Title/Content it works.
But when I go to:
Theme Paneel – Theme Fonts and change the fonts in Page Title/Content it does not work. It does work when I create a Page using Classic Editor, but not with TagDiv Composer.
Do you know how I can change the fonts, and titles on all Pages like I did for Posts?
I also have the same issues when changing the font of the Menu in Theme Panel.. there is no change.
You should edit the pages with the TagDiv Composer, and change the font. Documentation here: https://forum.tagdiv.com/font-customization/
Thank you, so just to clarify. If I want to change font size on a Page, I need to go to each page using TagDiv composer to General, Style, Post Content and change the font size to for example 20. And there is no way I can change ALL Pages to font size 20 at the same time as in Theme Panel with Posts? I have to make the individual change on each Page?
Can I create a template I can use for each Page?
You can create a template, set the font size once, and assign it to all posts. Page templates are different. You can’t assign one to all.
