Theme Panel – General post settings not applying
Seems like recently, what i configure in General post settings does not apply :
Examples :
-I set sharing button on top + bottom of article, it only shows for bottom (the previous config)
-I set to display related article by category, it still try to display by tag (no other tag found)
I disabled Super cache plugin, remove cache
Thank you in advance
Hello !
Actually the issue was solved using a workaround ? by editing the page layout in tag div composer
It doesnt follow the theme settings
