If your settings are missing from theme panel, then make sure you have Standard Pack installed and active.
If you use a cloud/PRO template, then please try to re-install TagDiv Composer plugin.
If you don’t mean this, please provide more information about your issue, screenshots and also your website link in order to help you.
