Theme panel not work
Hello, I tried to customize my template such as changing the colors of the theme, or adding a custom code, however it appears saved, but when I see the changes on the web, they do not appear, I have updated, cleared the cache and nothing. am I doing something wrong?
I also changed the server and reinstalled, and both have the same problem
Thank you
  • This topic was modified 6 years by bahinino.
Indeed if you are using PRO demos, the settings from theme panel will no affect website, because PRO Demos are build suing cloud template from tagDiv Cloud Library and are build/edit with tagDiv Composer. So if you want to edit the pages or templates you need to do it with tagDiv Composer, for pages -> https://i.imgur.com/FIDsl3X.png or cloud templates -> https://i.imgur.com/QUul6Mj.png
Let me know the results!
