Theme panel problem
When I log on to my website theme panel can not log in for 5 minutes.
Please check your system status parameters and set them according to this guide: https://forum.tagdiv.com/system-status-parameters-guide/
Also please try it without any plugins. Disable all of them except visual composer, clear cache and reset cdn files.
If the problem is still there, you can try to switch to a wp default theme and check again to see if it’s a WP problem.
