'Theme Panel' Problems
‘Newspaper’
‘Theme Panel’
‘Post Settings’
SHOW AUTHOR NAME – Disabled
SHOW AUTHOR BOX – Disabled
I did that, but it still seems.
Desktop = https://i.ibb.co/fC0n7ck/zas1.png
Mobile = https://i.ibb.co/TMJmnw8/zas2.jpg
I do not quite understand the problem, do you want to remove the author from the post? From what I can see you are using a single post template from tagDiv Cloud Library, for this will not apply the theme panel settings, you’ll need to edit the single post template with tagDiv Composer and remove the author name and box.
Hope this will help you!
