I have recently purchased Newspaper theme. I am trying to make changes through Theme Panel but after doing the changes whenever i try to do save settings, it just keeps on loading and no changes are reflected in the website. Can anybody confirm what could be the reason?
This usually appears because the server security module blocks the access to admin-ajax.php file. Try to verify the console for error while saving the settings on the Theme Panel, usually it displays a 403 or 404 error.
Contact your server administrator and explain the situation, as it’s requested many times during the a save the file it’s treated as threat so it’s banned. You can report false positives to your server administrator to remove it from the banned list.
Hi Lucian,
Thanks for replying back. I spoke to administrator and they confirmed that this may be happening because of the BPS security, so they added the bypass script code
RewriteCond %{REQUEST_URI} (admin-ajax\.php) [NC]
RewriteRule . – [S=2]
But still, the issue didn’t got solved. So, i have deactivated the BPS security, still issue remained the same. Do you know any other workaround which i can do or do i need to completely remove the WordPress from the site and then try everything from starting?
Thanks for helping.
Please send an e-mail to contact@tagdiv.com and provide your wp-admin user and pass so we can check this, also send an URL to this topic or specify your issue in detail.
