I’ve been unable to disable “Enable Comments on Post” “Show Author Box” “Show Author Name” as well as other options such as disabling the smart side bar. Nothing seems to be working and I have no idea why.
I’m using the Style Pro demo, so I tested another demo to see if that would change anything but it still doesn’t work.
This topic was modified 6 years by
ragemixer.
So, if I change the “Default Site Post Template” off the custom one, the settings start to work, but then it’s not the theme I chose anymore.
Why don’t those settings work with the Style Pro theme?
I don’t know how to make it work, I need some help here đ
The Pro demos are using cloud templates and for these the theme panel settings will not apply, the theme panel will change only the standard styles/templates. In order to edit a cloud template you’ll need to edit it with tagDiv Composer, for example if you are using a single post template you can edit it like this -> https://i.imgur.com/2nR57lo.png after that you can add and remove the elements.
I know you can edit the page with the tagdiv composer, but as far as I know, it’s not possible to disable/enable the smart sidebar from the composer, is that correct? which means if I’m using any cloud template I can’t customize that function?
I don’t believe you can toggle the Author name/box either, so I’d have to delete it with the composer and if I wanted to add it back in later for a different post, with the same style that matches the demo, I would have to re-apply the cloud template, which would overwrite any customization I would have done?
Hello !
You can have the sticky sidebar option by editing the sidebar column as you can see here: https://www.screencast.com/t/fBoy8gFet
If you import a new single post template from the cloud library the old one will remain saved in your Cloud Library.
I hope this was helpful !
