I updated the theme on a staging site (https://stefaniephan.staging.wpengine.com). Settings in the theme panel are not showing up on the front end.
For example, I have set the main menu to be always sticky but on the front end it’s not showing up. Wpengine advised that certain fonts were not coming over https (I’m not sure what that means) and to contact the theme developer.
Also, at the bottom of the home page I get this error: Fatal error: Call to undefined method td_util::vc_set_column_number() in /nas/content/staging/stefaniephan/wp-content/themes/newspaper-child/parts/footer/td_footer_template_1.php on line 17
Could you please advise?
It seems the move to https was not done correctly. Please use these few guides to help:
http://www.wpbeginner.com/wp-tutorials/how-to-add-ssl-and-https-in-wordpress/
https://css-tricks.com/moving-to-https-on-wordpress/
https://yoast.com/dev-blog/move-website-https-ssl/
You can also check our forum for some insight on ssl:
https://forum.tagdiv.com/topic/moving-to-ssl/
