Theme panel settings not working
I have the Zodiac Pro demo installed (http://p7d.d80.myftpupload.com/) and am trying to customize some options using the Theme Panel, however they are not displaying when I refresh my site (I am clearing the cache). For example, I want to change some Post Settings in the theme panel. I have clicked to hide category tags, page views, and author name and clicked save. When I refresh my post, all of these are still displaying (see test post here for example http://p7d.d80.myftpupload.com/blog/test/). I am also having this issue trying to change theme fonts.
Hi lfowle521
, if the settings from theme panel are not apply, then you are using a pro demo, this can be edited using tagDiv Composer -> use the right click to remove the elements you do not want to have in your single post template -> https://i.imgur.com/1gAnLJW.png- > https://i.imgur.com/xCG0Z8h.png
The font can be change by selecting the element and in general tab or style tab you can set the fonts -> https://i.imgur.com/Q5jKCVA.jpg also using the manager you can see what fonts do you have on that page or template -> https://i.imgur.com/55UMHqU.jpg from there you can go on that element or you can change the font directly in manager.
Hope this will help you!
