Theme Panel stuck saving settings
I recently purchased this theme and I’m loving it. However, I’m experiencing some problems with it. Whenever I change a setting in the theme panel and try to save said setting I’m greeted with a endless loading screen. Any help with this issue would be greatly appreciated.
Hello TigerCubOnline,
First of all, make sure that your system status parameters are according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/ Most likely, your PHP memory has exhausted and that’s why you cannot save anything, sorry!
My PHP memory is set to 128M, is that not enough?
PHP is set to 128M, is that not enough?
Hello Tiger,
This value of your PHP memory should have to be okay! First of all, check the theme install if it was made via FTP way because this is the surest method in this regard. Also, if you are using such untested plugins, you should disable all of them because these might interact with the theme core files and causes a lot of unknown issues. Try using the theme at default state, clear all of your caches and check the results.
