Theme Panel – Theme Fonts Post Title Not Reflected
Hello Support,
I am currently using your Newspaper Pro demo, but my default “Post title” font in the theme fonts of the theme panel is not reflected in the single post template instead of using my custom font but the family font remain “Rubik”. Here’s the screenshot
Theme panel: https://prnt.sc/vlouro
Single Post: https://prnt.sc/vloxi9
Need your input on how to change it so it will reflect all blog post articles by not editing the element via tagdiv composer.
If you are using the Newspaper Pro demo which has cloud templates for posts, categories, etc, then the modifications made in the theme fonts section of the theme panel will not be applied on these templates.
The solution for your problem is to edit a post with TagDiv Composer, select the element called Page Title and modify the font down there. When you modify a post like that, all your posts using that template will reflect the changes.
  • This reply was modified 6 years by Bettina.
Hi Bettina,
Thank you! But little bit confused about your instruction if that is applicable for a single post template? Because after I went to a single post then followed your instruction that will only be reflected for that specific post and will not be applied at once in the rest of the post. It is not good to edit each post one by one, that is time-consuming.
Also if you can provide a step-by-step screenshot much appreciated.
Hi codexxx,
In the following video, I went step by step to edit the post title font: https://www.screencast.com/t/1x1AGtZj
As I said you do it once and this will apply for every post.
Hope this helps you!
